I ordered a new oil pump from boats.net for my 1985 Yamaha 90ETLK and they sent me what they say is a superseded oil pump part# 6H1-WS132-00-00 along with an adapter, new linkage and check valves for the oil lines. Has anyone tried to install this pump because I could not get it to fit. The holes do not line up by about an 1/8th of an inch because the bottom of the oil pump hits the block. Even if I did get it to fit I have no idea which cylinders to hook the lines up to, their not marked. Or dose it matter? What should I do? Should I return it and use my old one that I don't have any idea how many hours are on it. Can I just rebuild the old one? If so where can I get an overhaul kit? Any help would be greatly appreciated. I just got my powerhead back from getting an overhaul because the center cylinder broke a ring and lost compression and I don't want to do this all over again.
