stangclassic66
- Apr 3, 2005
- 25
Hello Everyone,<br /><br />I took my boat out last Saturday for the first time since late December and it fired right up. Did not winterize the motor. Just periodically fired up the engine every two weeks or so.<br /><br />Let it warm up for about 10 minutes. Headed into the channel, everything seemed fine. Increased speed to 2500rpms, everything still fine. Looked ok and water was flat glass calm so decided to go my normal operating speed which was 4000-4200rpm. Boat planed up and was on it's way at 4000rpm at about 23kts. Running great...<br /><br />Then slowly the boat started slowing down and I was NOT touching the throttle. Boat started spitting and sputtering. Turned the boat around and could only get about 1500 rpm and 4kts. all the way back to the dock.<br /><br />The motor revs fine in neutral. Tested it all the way up to 3000+rpm. Just won't accelerate under load. If I push the throttle forward, it just spits and sputters and dies. Took the boat home and changed the plugs but I don't think it's that since it revs fine in neutral.<br /><br />This motor ran fine all last year with over a dozen trips with over 60 miles on every trip. I'm thinking possibly some gas evaporated and gummed up some spots in the carb. But who knows I could be way off. I pulled one spark plug and tested for spark it it sparked up fine.<br /><br />Any ideas. The wait time for the best marine mechanic I know is 3 weeks away. Was wondering if there was anything I could do before that time. The mechanic said it could be anything from water in the gas to the fuel pump to the high speed line in the carb.<br /><br />Thanks in advance.<br /><br />Erik
