ianyoung77
- Mar 28, 2005
- 121
G'day,<br /><br />I have a 50HP Yamaha (50DETO) and I want to tune the carby. According the the Clymer manual the carby should be stamped 62X00 with a 130 main and 62 pilot adjusted to 15mm float and 1.75 pilot screw. My carby is stamped 6H511 ED20 with a 135 main and 62 pilot. According to the yamaha parts site my carby should be 6H511 with 135 main and 60 pilot.<br /><br />My carby was set to about 14mm float (measured on side at maximum) and 2.25 pilot screw.<br /><br />When warm the motor can flat spot or stall on accelaration even after cleaning the carby spotless. I have now set the float at 14mm and adjusted the pilot screw to 1.75. I have yet to take it for a long run and am unsure of what settings to use since the manual does not seem to match my carby.<br /><br />Does anyone know what settings should work best?<br /><br />Thanks,<br /><br />Ian
