Re: Fast idle
I think what rodbolt is saying is that if you keep shifting gears at 1900 you are going to strip a few cogs and then, when you have to dismantle the gearbox you will see how it works. Do not change gears until you are sure that are at the recommended idle RPM. Have you tach checked to ensure that what you are seeing is in fact the truth.
