yamaha 30 hp , 1994 2 cylinder.<br /><br />the motor starts right away and has a lot of power .<br />only thing is that the motor was in storage<br />for a long time and when i checked the compression,,,<br />i was surprice that the lower cylinder reads<br />90 psi and the upper 70 psi...<br /><br />wow!! this is bad...in fact the motor doesnt have more than 100 hours of used.<br /><br />im thinking that the piston rings are stuck somehow because of the lenght in storage,<br /><br />PLEASE HELP...<br />what do i do? <br />do you thing it will come back to normal after using it for a while or<br />should i be very concern about this.<br />or this is normal???<br />im preety dissapointed.
