Its a 1998 elec. start 15hp four-stroke engine.<br /><br />I took her out yesterday for a spin and she never missed a beat, purred like a kitten.<br /><br />Today I took her out, she started ok, I let her idle for about a minute with the choke in, then I did a short circuit at about 4000rpm around a little island (only a few hundred yards). I throttled back and went to neutral to look over the back to check which hole I had the trim set to, and suddenly the engine conks out. When I tried starting it again, it would only run (roughly) with the choke pulled out and I couldn't shift into gear without stalling. At idle, the minute I put the choke in, she conks out again.<br />I checked and the vent was open on the tank.....any ideas whats wrong? The fuel should be fine since I had stabiliser in it.
