Re: outboard & marvel mystery oil
Air plains?<br />It is a mystery.<br />Sounds like an add to me.<br />Snooker me?<br /><br />
http://householdproducts.nlm.nih.gov/cgi-bin/household/brands?tbl=chem&id=167 <br /><br /><br />
http://www.vtr.org/maintain/oil-additives.html <br /><br />"All of these products will strip sludge and deposits out and clean up your engine, particularly if it is an older, abused one. The problem is, unless you have some way of determining just how much is needed to remove your deposits without going any further, such solvents also can strip away the boundary lubrication layer provided by your oil. Overuse of solvents is an easy trap to fall into, and one which can promote harmful metal-to-metal contact within your engine." <br /><br />"As a general rule of thumb these products had their place and were at least moderately useful on older automobile and motorcycle engines of the Fifties and Sixties, but are basically unneeded on the more efficient engine designs of the past two decades."<br /><br />"On the other hand, there has been documented, careful scientific analysis done on numerous oil additives by accredited institutions and researchers." <br /><br />"For example:" <br /><br />"Avco Lycoming, a major manufacturer of aircraft engines, states, "We have tried every additive we could find on the market, and they are all worthless." <br /><br />"Briggs and Stratton, renowned builders of some of the most durable engines in the world, says in their report on engine oil additives, "They do not appear to offer any benefits." <br /><br />"North Dakota State University conducted tests on oil additives and said in their report, "The theory sounds good- the only problem is that the products simply don't work." <br /><br />"And finally, Ed Hackett, chemist at the University of Nevada Desert Research Center, says, "Oil additives should not be used. The oil companies have gone to great lengths to develop an additive pack age that meets the vehicle's requirements. If you add anything to this oil you may upset the balance and prevent the oil from performing to specification."
