Hi, I have a dt 5 Suzuki that starts after 5 to 10 full choke pulls. When you put it in gear at low rpm, it has no power and dies ( in the 55 gal.test tank).I have swaped out carb and power pack from another dt5 and this did not effect any thing. I suspect possible bad crank seals , intake leak some where?, reed valve, exhaust port restriction or a head gasket problem. What is the most common problem for this complaint. What should the compresion be using a snap-on compression tester? 125psi? The carb works fine on the other dt5 doner. <br /> <br />Any ideas would sure help. Thank's Pat.
