when wot seems like its loading up???
edjr
92 suzuki dt140 idles great when engaged it runs smooth but when you try to go wot it seems like its loading up? is it to rich??? any suggestions??
walleyehed
Re: when wot seems like its loading up???
Fresh fuel??? New plugs???<br />Is this a new problem or have you had this experience before?
edjr
i just bought the boat. new plugs, decarbed the motor,11 gallons of fresh fuel
rodbolt
hello<br /> check the timing. if the throttle switch is bad it wont allow ign advance. if the boat sat for anylength of time remove and clean the carbs.<br /> this is after a spark and compression test.
edjr
the boat has sat for almost a yr. sending it dealer tomorrow to see what they will charge to find out what it might be. it has good spark, compression is around 110 in all 4 cyl. ran some decharbing spray through the carbs and in the cyls. besides tearing the carbs apart is there any thing else i should try
rodbolt
nope<br /> if it sat a year odds are the carbs are fouled.
edjr
ok thanks for your input and my hats off to you for all you knowledge god bless you and have a good day
