Re: New Yamaha's garden hose connector
Tacklebuster,<br />You are correct, the Manual say You should not<br />run the outboard while using the garden house connector:<br /><br />"Flushing power unit:<br /><br />Perform this procedure right after operation<br />for the most thorough flushing.<br />1. After shutting off the engine, unscrew the<br /> garden hose connector from the fitting on<br />the bottom cowling.<br />2. Screw the garden hose connector onto a<br />garden hose which is connected to a<br />fresh water supply.<br />3. With the engine off , turn on the water tap<br />and let the water flush through the cooling<br />passages for about 15 minutes. Turn<br />off the water and disconnect the garden<br />hose.<br />4. When flushing is complete, reinstall the<br />garden hose connector on the fitting on<br />the bottom cowling. Tighten the connector<br />securely.<br /><br />Page 44, Yamaha F150 Owners's Manual.<br /><br /><br />Flushing with the flushing attachment:<br />...<br />4. Install the flushing attachment over the<br />cooling water inlet .<br />5. Cooling system flushing is essential to<br />prevent the cooling system from clogging<br />up with salt, sand, or dirt. In addition, fog-<br />ging/lubricating of the engine is mandato-<br />ry to prevent excessive engine damage<br />due to rust. Perform the flushing and fog-<br />ging at the same time.<br />6. Run the engine at a fast idle for a few<br />minutes in neutral position while supply-<br />ing fresh water.<br />...<br /><br />Do not run the engine without supplying it<br />with cooling water. Either the engine water<br />pump will be damaged or the engine will<br />be damaged from overheating. Before<br />starting the engine, be sure to supply water<br />to the cooling water passages.<br /><br />Avoid running the outboard motor at high<br />speed while on the flushing attachment,<br />otherwise overheating could occur.<br /><br />When using the flushing attachment, main-<br />tain adequate water pressure and a steady<br />water flow.<br />If the overheat warning device is activated,<br />turn the engine off, and consult your<br />Yamaha dealer."<br /><br />Page 42-43, Yamaha F150 Owners's Manual.
