Re: Power T&T
i havent seen it ever go bad? if there was a service interval it would probably be 500 hours+<br />to tell if you need more trim your leg fully up and flip down the tilt locks. facing the tnt unit you will see a bolt head half way up the resevoir. undo it, if fluid dribbles out then no. if it dribbles out and its not red but milky/creamy then you have a leak somewhere. n oil can and fill to this level. replace the plug and you are good to go.
