hello<br /> while they are all similar they are not all the same from the control/ign switch to the engine. some are 7 pin and some are 10 pin. and a few do not contain the yellow ign 12V positive wire. you will need to post a model number to find the correct harness.
Thanks i did'ent know i will check the motor tomorrow, if i post the model number will you be able to tell me the year of the motor??<br /><br />Thanks a lot Andreas
