hello i have got an 1985 yammy 200 when it sits<br />for a month or so the oil in the resovoir on the engine drains into the crankcase through the oil<br />injection ports i verified by removing the carbs and the oil pump and keeping the lines connected on the oil pump to see if it was from the shaft<br />but it is coming through the injection lines dripping very slowly, i also noticed it does not have or take the check valves like the newer motors, can you guys give me any suggestions on what could be causing this? is it the oil pump?<br />on the website (yammy) they only offer a kit to repair? i dont want to damage this motor and you can imagine fouled plugs!! landlocked for now<br />thanks
