Re: Tilt Trim at WOT
You don't state what year your F90 is. Many later four-stroke Yams have a tilt lock out that stops the motor tilting (but allows trimming) when above idle. My 03 F60 trims all the way up and down at any speed, but won't tilt above idle. This is a safety feature. Do you have a trim gauge? If so, try the following test.<br />When parked up put the motor in the fully down position. Check the gauge - it should show fully down. Then use the trim/tilt button on the side of the motor to trim up. The main trim motor will start to lift the motor. Keep trimming up watching the lower leg. It should smoothly trim up about 6 inches then hesitate, then start moving up more quickly accompanied by a slightly louder electrical motor noise. This is the point when the tilt side of things kicks in.<br />Trim back down and then up until the hesitation point. Stop trimming and check the gauge. It should show fully up. When you're on the water this is the range you can use. If the motor keeps coming up when you're above idle, then you don't have a lock out or it's not working. I suggest restricting your trimming to the range shown by the gauge as you wouldn't want to bugger the tilt motor.
