Re: Overheated using muffs. Telltale weak. Common with muffs?
My poppet valve on my Yamaha C115 (250 hours) became sticky with corrosion/deposits and stuck open, and I rinse the salt out with fresh water religiously! My water pressure gauge was reading low and I thought my water pump was bad...changed pump...still low pressure, because the poppet valve was stuck open and dumping out the majority of the cooling water= low pressure and elevated temperature. Be sure to really clean the rubber seat well..vinegar and a toothpick or some other device that can scrape off the crud but not damage the rubber. Put anti seize on the mounting bolts. Oh yeah, I meant to mention that I run my motor in an old salvaged deep bath tub and I get FULL pressure (18 - 20 lbs.) from about 1200rpm's up...it even reads a few pounds at idle. It's a great way to be able to bench run the motor with NO fear of overheating. Keep a hose running into the tub to compensate for the water lost out of the pee hole. I installed a water pressure and temperature gauge...wouldn't own a boat without them. You can really keep an eye of what's going on and actually diagnose problems by using them. One more thing, when a poppet valve gets stuck open, the pee stream is still coming out but at a really reduced level...at high rpm that could mean trouble. There's water pressure but not near enough. The pee hole is a device only slightly more evolved than an idiot light.
