Re: Whats a good prop for Yam 90hp?
Don't know if this is right place to ask about a prop for my FT60B Yamaha, so I'll apologise in advance for my lack of forum manners if it's the wrong place. But, anyway, here goes. The motor came with a 13.5in x 15 pitch Yamaha aluminium prop. The motor powers a 16.5ft Quintrex Cuddy Cabin that weighs about 1400lbs with motor but without fuel. The problem is the thing seems a little bit over-propped... it does 4kts (GPS) at idle and will only rev to 5400rpm one up or about 28kts with a half tank of gas (11 US gallons). I'd like to slow down the boat at idle to about 3kts and see a few more rpm (about 5900)at WOT in the hope of maybe getting an extra knot or two out of her.<br />I know I should have put an 80 on the thing, but the fourstroke Yam 60 weighs 270lbs whereas the 80 weighs in at close to 400 and I (probably falsely) thought the extra weight would create extra drag and reduce the performance gained by having 20 more HP.<br />Sorry, started rambling... anyway, my questions are: What size/brand prop should I look at to achieve the objectives listed above? Is a SS prop worth the extra money? Any help gratefully received.
