Re: 91 Yamaha 200 stalls at idle speed
Thank you for your feedback. I agree it does sound like a possible fuel filter problem, and I will check it. But, this problem occured while on an extended trip, and I had been running it for days with no problems, on the same tank of fuel. It also runs fine once the RPMs are high enough. Nothing had changed except it being in for service, and the lower unit being removed to replace the water pump. (I think?) Should I try adjusting the idle speed? I know the adjustment is made on the carb, but do you happen to know the location of the adjustment screw? I am a novice at this, but understand engine systems. I have also heard that there is a retainer clip or something on the lower unit gasket? that, if left off after serviceing, allows water to enter part of the engine that causes it to stall at low idle. Not sure if this is from a reputable source. <br />Also: How do I perform a compression test? Thanks again.
