floridaham42
- Oct 7, 2004
- 2
I'm trying to help out a friend in Brazil with this problem.His outboard just quit running.He replaced the plugs with new ones ,also replaced the 'big coil' under the flywheel with one that was good,still no spark.I say 'big coil' because that is a literal translation of the term they use,and I am not familiar enough with this motor to give the correct part name.He tells me it has electronic ignition.Any help would be appreciated as this is his only method of transportation other than rowing.
