Re: Yamaha fuel gauge
I bought a Floscan in 1999 for my 1992 20' Tiderunner that I have a 150 Yamaha on. I paid $300 for it then. Think I got it at Boaters World or West Marine. <br /><br />You need to pick the right size for the size of the engine. Then run it, check your fuel consumption, calibrate the meter. You might have to redo this calibration 3-4 times to get it close to your actual consumption.<br /><br />I am sold on mine. It may vary slightly depending on whether I troll with the big motor or not. But usually I can be within 1/2 gallon + - of the actual usage when refueling 40 gallons or so.<br /><br />You will also be supprised at how you will begin to throttle back to find a good consumption rate. Many times only 200 RPM will make a difference of 10 & 13 GPH with little change in actual speed.<br /><br />Once I spent a long week-end at Neah Bay & was limping along on a low tank the 3rd day as we were coming in at noon. As we ran in the harbor, I just happened to be watching the meter & the gauge was fluxuating between 8 & 3 GPH. I have a spare 6 gallon tank on the stern step, preplumbed into a Tee with shut-off valves. I had the son switch the valves & the motor never knew it was running out of gas. The meter had picked up the low flow before the carbs ran dry.
