dberk7555tully
- Sep 21, 2004
- 1
My F50 won't reach the recommended max RPM at WOT (5000-6000.) It WILL reach max RPM while in neutral (pushing just the throttle lever up.) However, while in gear it only gets to 4300 RPM at WOT. <br /><br />I have already - <br />- Prop'd down to the lowest pitch offered for this engine (which got me from 3000 up to my current 4300 RPM) so lower pitch is not an option. <br />- Had compression checked before I bought it.<br />- Checked the throttle cable to ensure it was pulling everything wide open - it was. <br /><br />It is also prone to stalling under acceleration (in gear) unless you accelerate slowly.<br /><br />Any ideas?
