bubbakat
- Oct 29, 2002
- 3,110
A 1994 85 h/p yamaha Rebuilt carbs and replaced all fuel lines to carb. Checked output at fuel pump. It is working good. I have interment-en firing on the top cylinder. Swapped coils around and it stayed with the top cylinder. How do you check the power pack on the side of the engine to tell if it is breaking down there.<br />I cleaned all connections (grounds)<br />Compression is 120 top to bottom
