bubbakat
- Oct 29, 2002
- 3,110
I am helping a friend with his 1994 85 h/p yahama on his toon and it has a fuel problem. I am in the process of rebuilding the carbs. I also pulled the pick up tube out of the tank and it is clear but the check valve that goes in line here will barely<sp> let any air thru it. My question is can you soak these or do you replace them.
