Re: 2001 200HP HPDI Oil Leak
I have had minor 2 stroke leaks on two outboards and can offer the following possible causes. The oil is not leaking from the base of the powerhead. Its pooling there after leaking down from above. First are nylon wire-ties and small hose clamps at connection points of oiling system hoses. Check around all hose connections that are part of oil injection system looking for any sign of a leak, replace any wire-ties or clamps that look to be a problem. Second are any sensor caps or other fittings in the primary oil resevior that are below oil level.
