  #1
Old June 22nd, 2006, 06:42 AM
HeadHunt HeadHunt is offline
Default Racor vs, Yamaha 10 Micron Filter
At the advice of my Yamaha mechanic, I am using the Yamaha 10 micron water separator filter instead of the Racor with the sight bowl. He gave me an explanation why the Yamaha was better but I do not remember what he said. All my buddies are using the Racor with the bowl but that filter looks so small compared to the Yamaha.What is the advantage of using the Yamaha filter? If you see water in the bowl of the Racor is it too late? I have also heard that when the filter gets full, water will pass through to the engine, correct?Thanks,HH
  #2
Old June 23rd, 2006, 09:54 PM
Casco Bay Outrage Casco Bay Outrage is offline
Default Re: Racor vs, Yamaha 10 Micron Filter
Would surmise the Yamaha is more expensive.
The purpose of the bowl is so you can drain it off. If the bowl is full, water will get into the fuel cartridge under the cowling and eventually into the engine.
If you have to drain your bowl frequently, you have either a bad gas supplier or a leak in your tank(s)
After 1-200 engine hours, I only get a 1/2 inch of water in my seperator. Then again, I fill up at a gas station and not a marina. Make it a routine to check the bowl each time you go out.
__________________
1991 Boston Whaler Outrage 17
2003 Yamaha F115
  #3
Old June 23rd, 2006, 10:51 PM
Propnuts Propnuts is offline
Both Yamaha blue and most Racors filters are rated at filtering particles to 10 microns....the Yamaha blue filter is rated at a 90gph flow and the smaller Racors are 60. Racor also makes a 90gph but the element thead size is bigger. Any of the Yamaha engines will never come close to either of those flow ratings but in theory the Yamaha has a longer life because of its bigger filter area.
I prefer the Racor because you can see the fuel(clear bowl) whereas the Yamaha you have to dump the filter to check for water.
Quality wise I feel there is no difference. I would have to disagree with Yamaha mech saying the Yamaha is "better". I would say its personal preference.
  #4
Old June 24th, 2006, 08:11 AM
If you see water in the bowl of the Racor is it too late? I have also heard that when the filter gets full, water will pass through to the engine, correct? The Yamaha filter @ 90GPH is three times larger than the 90GPH Racor. I think this is why the tech was telling me to do with the Yamaha.
HH
  #5
Old June 24th, 2006, 11:11 AM
Either filter type can fill with water if water is present in the fuel system. If there is that much water in your system, you got other problems that need to be addressed. Like physically removing it and not relying on a water seperator to handle it.
Yes if either filter gets full of water it will pass through either. Yes the Yamaha is a bigger filter and could handle more water but like I said if you have that much water.....you have other problems.
There is nothing wrong with using either and both meet the 10 Micron Yamaha spec. But given a choice I would use the Racor 60gph with bowl in a outboard engine install just because I can do a physical check for water and or debris without removing the filter and dumping it out. Plain and simple.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Racor Gasoline Filter for Mercruiser drs416 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 October 27th, 2006 03:40 AM
Racor Fuel Filter Question CMBarnes Boat Topics and Questions (not engine topics) 4 April 8th, 2005 11:40 AM
Racor Filter twofing Yamaha & Suzuki Outboards 2 March 5th, 2005 07:35 PM
TEFLON TAPE/RACOR FILTER playnsnookie Yamaha & Suzuki Outboards 10 February 22nd, 2005 03:34 AM
racor filter question? spete Yamaha & Suzuki Outboards 13 March 7th, 2003 08:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
