Re: GPS cost
Alright, a laptop kit. When you get water on the laptop, I would be happy to provide service, just post and I'll give an estimate. Seriously, on a large boat in a protected environment, it would be ok, but I would never suggest it. Also, if used on salt water it would be bad because of the salt water mist. On most high end laptops, they have a fan to pull cooling air in that would pull moisture in. There is an exception though. panasonic makes a tough book that is competely sealed and can stand drops to the ground. Expensive, but if you already have one or need to use one on the boat, then go for it. Bet you can't tell I run a computer service department. Boy do I have the stories, but that would be for another board. Honest, water only slightly dripped on the keyboard.
