  #1
Old June 17th, 2006, 09:43 AM
2manyboats 2manyboats is offline
Default 1986 Yamaha 150 oil injection
My oil injection spills oil into the engine housing when not running and the batteries are turned off. I'm not roo much of a mechanic, but can usually fix stuff with instruction. Help?
  #2
Old June 17th, 2006, 10:05 AM
Ray Neudecker Ray Neudecker is offline
Default Re: 1986 Yamaha 150 oil injection
Not sure how it can happen with the engine power off. Normal cause is the sensor in the engine monted oil tank or the oil control module being shorted.
  #3
Old June 23rd, 2006, 09:00 PM
cookiedoh cookiedoh is offline
Is it like a little spill dripping out of the vents at the top of the tank or a constant flow of oil pumping out? It's possible that your tank sensor is restricted so the control module thinks the tank is low. Are you sure it's not overfilling the oil tank while it's running and you just didn't notice until after? The pump is electrical, so if the battery is disconnected and it still activley leaks the only thing I can think of is an actual oil leak, like a broken oil line off the tank.
  #4
Old June 24th, 2006, 08:59 AM
The most common problem is the control unit overfilling the tank and the excess going into the airbox. When it sits it drains out into the cowling. this can be either a controller shorted or the tank sensor bad. First test is to turn on the ignition and see if the pump runs after the oil has reached the normal level marked on the tank.
  #5
Old June 30th, 2006, 07:16 PM
Thanks for the notes. Sorry to take so long to get back. I'll take her out for a spin to check the options.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Yamaha 130 want to remove oil injection ??? fishon71 Yamaha & Suzuki Outboards 6 April 28th, 2005 06:52 PM
1986 Evinrude 60 hp oil injection PATMANFAB Johnson & Evinrude Outboards 5 March 22nd, 2005 03:11 PM
1986 135 mercury oil injection mbdb3 Mercury & Mariner Outboards 3 July 26th, 2003 08:55 AM
Mercury 1986 35HP oil injection Mercury Dave Mercury & Mariner Outboards 0 March 18th, 2003 10:47 AM
1986 Merc 135 OIL INJECTION DISCONNECT clone1008 Mercury & Mariner Outboards 4 December 10th, 2001 05:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
