  #1
Old June 6th, 2006, 09:46 AM
hiflyer hiflyer is offline
Default yamaha 115 2st dies at 1100 or less rpm
apox 25 hrs total time, on engine was real bad till i cleaned the carbs junk in lower mainly little in upper.stalls 1/4 as much a little choaking helps a lot. fig its runing lean. how do I richen the mix? or could it be a weak fuel pump? also question on floats have black substance on them normal or should they be bright brass rockman
  #2
Old June 6th, 2006, 04:47 PM
rodbolt rodbolt is offline
Default Re: yamaha 115 2st dies at 1100 or less rpm
dude I have no clue what your asking, rephase it to include year model and a description of what it wont do. my guess is something is still in one of the carb circuits, however I always reccomend a spark and compression test as a first point of entry.
  #3
Old June 7th, 2006, 05:08 AM
Ray Neudecker Ray Neudecker is offline
Best I can tell from your post, I would agree with rodbolt, it would seem you have a fuel restriction. I would replace the fuel pump and tear down and properly rebuild the carbs.
  #4
Old June 8th, 2006, 05:46 AM
Quote:
Originally posted by Ray Neudecker: Best I can tell from your post, I would agree with rodbolt, it would seem you have a fuel restriction. I would replace the fuel pump and tear down and properly rebuild the carbs.
  #5
Old June 8th, 2006, 05:57 AM
the carbs were striped all passages were cleaned and blown out. It is a 2002 model 115 hp 2 cycle. With 2, 2 barrel carbs. each carb looks more like 2 singles moulded together to make 1, 2 barrell. Net effect 1 venturi feeds each cycl. as a independent unite.exp manny auto and aircraft cabs no crashes do something right. Its clean!! fuel pump or lean mix more like problem how do you richen the mixSelling it want it to run right but not buy manual if possiable. Thanks rockman
  #6
Old June 8th, 2006, 03:57 PM
dorkhead dorkhead is offline
WWWhhhhaaaaaaaaaattttttt?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Removing Engine on Yamaha Waveraider 1100 bamadave PWC (Jetskis, Waverunners, etc.) 4 July 9th, 2006 10:14 AM
1997 yamaha waveventure 1100 billybobga PWC (Jetskis, Waverunners, etc.) 1 July 7th, 2006 08:34 AM
Yamaha Waverunner 1100 Fuel Problem? friscokid PWC (Jetskis, Waverunners, etc.) 2 August 31st, 2004 06:09 PM
'95 triple 1100 Yamaha jetski (cuts off when rpm's get to high) squeak1712 Yamaha & Suzuki Outboards 3 June 11th, 2002 02:46 PM
Yamaha Experts-2000 Yamaha 225 OX66 EFI-WOT Dies wi1p Yamaha & Suzuki Outboards 2 March 12th, 2002 02:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
