Re: What props for DT200?
There are lots of props around for them, but I don't know how many 15x17's I've seen around. I was using a 14.25x17 on a DT-200, but actually I ran quite a few props on that engine over the years. I had a 15, 17, and 19" Michigan Wheel Rapture, a Suzuki 20, 22, and 24 on it, and finally a Power Tech 14.25x16 4-blade. Oh, and I also have an older Michigan Wheel prop with no model name, but its a non-vented 14.5x19 (or maybe 20) with lots of rake. Its just a large gearbox 15 tooth spline. Most of the big V-6 props will work I believe, I know a guy who runs a Merc prop on his DT-225 and I know one of my old props ended up on an Evenrude. You might have to use some sort of spacers but that's all.<br /><br />By the way, if you find yourself looking at or comparing with Suzuki props don't forget that they overstate their pitch by two or three inches. A Suzuki prop in 20 pitch will act like anyone elses 17 inch.<br /><br />Thom
