  #1
Old May 6th, 2006, 12:29 PM
mtmaloney mtmaloney is offline
Default Yamaha 115, 2 cycle, blowing fuses
Main fuse overheats. After running hard for 30 minutes (+/-) it melts. Volt meter shows 14.2+ at 4800 rpm. Replaced regulator but that did not solve problem. Dealer and trusted mechanic have no insight.
  #2
Old May 6th, 2006, 02:47 PM
rodbolt rodbolt is offline
Default Re: Yamaha 115, 2 cycle, blowing fuses
sounds like a wire chafed, the voltage numbers look ok. usually its in the trim harness but occasionally in the remote oil tank or main engine harness.last one I looked at was someone had put a 10 amp fuse in place of the original 30 amp fuse . 2 other techs missed it.
  #3
Old May 7th, 2006, 03:22 AM
Seems credible. We started having the problem after running for twenty minutes or so in pretty rough seas. How can we find it?The first time it happened, the mechanic at the place that sold us the motor claimed that someone had put in a fuse that was too short. That proved to be an elusive fix.
  #4
Old May 7th, 2006, 04:25 AM
Ray Neudecker Ray Neudecker is offline
First I would check all connectons at the motor with special attention to grounds. Then examine the wiring harnesses for the trim and oil tank for wires which are bare or obviously been hot.
  #5
Old May 7th, 2006, 11:27 AM
We have a '03, 115TXRB.There are two things labeled as wiring harnesses in the wiring diagram. #30 is the main engine harness. It is the main fuse here that is melting. #34 is another harness -- I presume the oil injection.#43 is the tilt/trim switch. I assume that we should check (a) all the grounding points in the engine compartment; and (b) for hot wires associated with the tilt/trim and other wiring harness.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
90 HP Yamaha Blowing Fuses barbender55 Yamaha & Suzuki Outboards 4 April 18th, 2006 08:11 AM
I keep blowing fuses in my F-150. plaid_retina Trailers and Towing 8 March 28th, 2006 06:16 AM
Yamaha 150 Blowing Fuses! alaskamarine Yamaha & Suzuki Outboards 6 May 31st, 2005 08:51 PM
blowing fuses cmuggs Electrics, Electronics and Trolling Motors 8 May 12th, 2004 07:15 PM
Blowing fuses Knoxes Trailers and Towing 3 May 13th, 2003 05:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
