no water exhausting from this recently purchased outboard engine. there is an exhaust port on upper rear of leg, exhausts smoke & hot air, but no water. have run the engine in drum of water as well as with hose adaptor. everything looks clean, but has been run in salt water so may be plugged. what nightmares might i be looking at if i drop the bottom of the leg off to clean up the impeller etc.?? Thank you for any help.
