Re: 50 hp yamaha please help
The only thing I can think of that you're talking about it the water jacket plate on the exhaust manifold. There are two plates and 2 gaskets. Don't reuse gaskets, so replace them both. They are only $10 to $15 apiece, so do it right the first time. The torque specs are on the exterior plate. I use the high temp silicone just to hold the gasket in place while assembling, it makes it easier since the gasket won't move around. oh, use a razor blade or something sharp to get the old gasket off. Since you do expose the combustion chanber, make sure you don't get any old gasket material in the engine. good luck, I broke 3 of the 15 bolts, so be careful or you'll be reading the "broken powerhead bolt" forum 3 down like me, haha
