I recently purchased a 95 yam 70hp, it preforms great, but the overheat buzzer goes off if idling or running under 16000 rpm. If i run at higher rpm's it will preform flawlessly. Has good water flow even when the buzzer is going off. My question is how to tell if I need a water pump or temp sensor??? Or could I have a different problem?
