I have a 1988 70 yam that is overheating and tripping alarm at high RPM, above 4200 rpm. I replaced water impeller with kit. Motor runs all day under 4000RPM. Thermodisc tested ok. Compression is 130psi top,125psi middle, 122psi bottom. I was told could be possible head gasket or Carbs too lean. Ran motor until alarmed checked compression still around 125psi but plugs looked dry and alittle white/brown. Checked plugs after running at idle and they looked wet and dark. Could this be a cracked head or gasket or Does it seem to be running too lean. How can I determine a faulty head or gasket. Can I run 50:1 gas mixture and plug oil pump to check if it is working properly? How do i know if the carbs are too lean. The motor idles perfect. It seems like it has a very slight miss after running.<br />Thanks for the help
