  #1
Old April 21st, 2006, 08:38 PM
formula233 formula233 is offline
Default yamaha 115 fouling plugs
Hello I have a 2000 yamaha c115,non injected,engine mounted on a older 17 aquasport center console,21 pitch prop.It will turn 5300 - 5500 rpm. depending on weight.The engine runs great while planed off.Even when you first leave the ramp idling 15 minutes,with clean plugs,no problem.The first time you plane off, perfect,the problem starts when you decelerate back to trolling speed or idle.It sounds like its running off 2 cylinders or so.After that, it will not ever idle right again.Come home and clean the plugs,idles and runs good.The carbs were just done and fuel pump replaced.So when the plugs are clean it runs,ignition must be ok or not? First time, I took off one wire at a time,and the port top and bottom cylinder were the ones foul.All look rather wet.Would it mean both carbs would have to be bad in order for all plugs to be wet.Idle screws are set at 1 turn out.Engine is new to me,I don't suppose a decarb would fix this,probably wouldn't hurt though or am i wrong?Thanks 233
  #2
Old April 22nd, 2006, 04:19 AM
rodbolt rodbolt is offline
Default Re: yamaha 115 fouling plugs
while a decarb wont hurt I doubt it will help. you need to carefully check the ign system and your oil mix.plug fouling is a symptom that all is not well in the motor. when you say they are fouled what do the actually look like? start with the basics, spark test at about a 7/16th gap and compression test. carbs just done is meaningless to me cause I redo them on a weekly basis . but for now you need to insure the ign system is capeable of making spark with reserve voltage and the compression is correct.
  #3
Old April 22nd, 2006, 04:20 AM
JB's Avatar
JB JB is online now
Yamaha Trouble
__________________
RED SKY at night. . .
JB
  #4
Old April 22nd, 2006, 07:55 AM
Thank you,The spark plugs are really just wet,not black.I checked the fuel for water,its ok.If the plugs will jump the 7/16 gap,does this mean there is reserve voltage.A friend,who is a yamaha tech, did the carbs.I know that doesn't mean he didn't miss something.I did check compression and it was 125 on each cylinder.I will look into the spark,if good I guess its back into the carbs.I'll return later with results.Thanks for the help, 233
  #5
Old April 22nd, 2006, 07:57 AM
its still possible a float or two is not set correctly, new fuel pumps have been known to be bad, but if the ign system is not capeable of keeping the mix lit wet fouling can result as well.
  #6
Old April 23rd, 2006, 04:31 AM
Ray Neudecker Ray Neudecker is offline
Often a float level causes this problem.1 1/4 to 1 1/2 turns seems to work better on those carbs.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'91 Yamaha 130 HP Fouling plugs Gr8NW Yamaha & Suzuki Outboards 1 September 6th, 2006 07:21 AM
yamaha 115 fouling plugs formula233 Non-Repair Outboard Discussions 2 April 22nd, 2006 04:20 AM
250 efi fouling plugs bucsfan1973 Mercury & Mariner Outboards 5 February 5th, 2006 12:56 PM
130 Yamaha gas-fouling port side plugs after 15-20 hours 88maverick Yamaha & Suzuki Outboards 6 May 21st, 2004 08:33 PM
Yamaha Continually Fouling Plugs cwhisen Yamaha & Suzuki Outboards 3 July 1st, 2002 11:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
