ya have to use the service manual. but a quick check is to use a voltmeter and test the voltage output of the rectifier/regulator. if its ok at the output there start looking at the battery cables and how the battery isolator wiring was run. some of the 3.1 motors used a 3 lead battery cable and the little lead was prone to break.
other than that its inputs and outputs, garbage in ,garbage out.
good in,garbage out, ya found the problem.
that stator system uses a 3 phase altenator, check the resistance of each green to green and each green to ground.
