  #1
Old April 10th, 2006, 07:06 PM
ladano ladano is offline
Default yamaha temp gauge and dig speedo
I have a '92 85hp yamaha and I'm tring to add a yamaha temp gauge. It has 3 wires off the back along with the 2 lighting wires, yellow,light blue, and black. The light blue one is giving me the trouble. Where does it connect to? The guy at the yamaha counter said it ties into the overheat alarm sending unit, but how. My 2nd problem is that I got a yamaha dig speedo and the "set/mode" buttons do nothing. It has a 's video' type connector on the back that is not hooked up. Should it be? Where can I locate a schematic on this? I do appreciate all the help I've recieved in the past very much. Everyone here has saved me a lot of time and money that the wife doesn't like to share with a mechanic. Thanx again
  #2
Old April 11th, 2006, 05:29 AM
rodbolt rodbolt is offline
Default Re: yamaha temp gauge and dig speedo
that tach is really not compatible with the 92 unless you purchase the wire harness adapter. in 95 the harness changed from a round connector to a square and the tachs with the mode/set buttons were not made until the late 90's early 2000's. and ya need to insure the DIP switch settings in the tach are set for 3 wire trim,12pole and 2 stroke as applicable. use the search funtion on the yamaha forum for tach dip switch. got no idea of what an "s" video is, yellow is key on 12V,black is ground lighting is dark blue and that only leaves the light blue for send.
  #3
Old April 11th, 2006, 10:58 AM
Its a digital speedometer, is that still going to be about the same problem as a tach? Thanx
  #4
Old April 12th, 2006, 07:09 AM
Rodbolt, does the temp gauge use the same sending unit that the alarm buzzer uses? My local shop has no clue. Thanx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Temp Gauge Sender Question jak Yamaha & Suzuki Outboards 5 January 26th, 2009 09:33 AM
temp gauge 115 85 yamaha defcondaze Yamaha & Suzuki Outboards 3 October 20th, 2005 05:31 AM
yamaha temp gauge installation and wiring wmvoss Yamaha & Suzuki Outboards 1 August 23rd, 2005 06:17 PM
Yamaha Multifunction Gauge Temp Indicator slow530 Yamaha & Suzuki Outboards 3 August 19th, 2005 08:32 AM
Water Temp Gauge, Temp Sensors, Wiring Flash Wax Man Johnson & Evinrude Outboards 2 July 19th, 2003 04:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
