Re: 2002 90hp Yami, hose question
If you should use the speedometer make sure that your pito hole isn't plugged (look at the leading edge of the lower gear house).<br />Depenfing of the water you are running you can expect better or worse funtionality from the speedometer, if the pitot hole get clogged you will not see any reading or you will have incorect readings.<br />A digital multi instrument from yamaha cost about 300$ but that include voltage, trip and time info as well. These functions are probably included in the GPS an lots more.
