  #1
Old April 1st, 2006, 11:11 AM
mish mish is offline
Default Yamaha F100 acceleration dip (solved?)
Hello guys,I looked for this topic, but i didn't found the answer.I try to explane my problem. Sorry, my english is not so good...I have a Yamaha F100 four stroke from 1999. The boat is a normal console boat (5 meter, 470 kilogram). The prop is a 19 pitch.When i give (from stationair trottle in forward direction) in one time full trottle, the motor has a little dip (1 second or so). It seems it has too little fuel. That is the only dip in the rpm range. When the nose is down, no problem anymore. Normaly i give first half trottle, then full, also no problem. Only when the motor from 1000 rpm to full trottle.I think it is better when i give quite trottle than trottle in one move, but maybe i can fix this problem easily.Thanks and greetings from the Netherlands,Mish
  #2
Old April 2nd, 2006, 04:12 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Yamaha F100 acceleration dip (solved?)
It sounds like your carbs may need synchronizing. That's something you need equipment for. You can't do it yourself without it. Also try running some automotive fuel system cleaner in the gas. That may help dissolve any varnishing that may be restricting a passage in the carb.Your English is Fine!
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old April 2nd, 2006, 04:13 AM
rodbolt rodbolt is offline
throttle lag is very common on 4 stroke carburated motors, if its not actually spitting back or backfireing its most likly normal. there is an accelerator pump setup to help make the fuel go richer when rapid shutter opening occurs. next time your in a manual shift auto, place the transmission in high gear, at 1000 RPM floorboard it rapidly and see if it lags and see how long it takes to build up RPM. that boat motor is fighting the same problem that car motor is. do you have the F100 service manual?
  #4
Old April 2nd, 2006, 10:24 AM
He Guys,Thanks for the responding, glad that my english is not so bad.. Willy@ next time i try automotive fuel system cleaner in the gas. Thanks for the tip.Rodbolt@ The motor runs very smootly. No spitting back or backfireing or something. On every range there is no problem, only with a low RPM. I tried also a higher RPM (1200). The throttle lag stays. I think by 2000 RPM the problem is solved. I must try it next time.I have no problem with it, if it is a common problem with the carburator 4 stroke. Normaly i move smootly the throttle open. But, if it is not normal, i want to solve it...I have only a owner manual. I want to buy a F100 service manual (technical part for mechanics?). Prefer dutch Thanks for all the respons!Mish
  #5
Old April 2nd, 2006, 12:43 PM
bossee bossee is offline
Hi,Also make sure You do not have any water in fuel. Use a fuel/water separating filter (like Racor or orginal Yamaha filter - basically same by the way, Racor makes almost all such filters). I belive service manuals for Yamaha outboards are only available in English.
  #6
Old April 2nd, 2006, 09:37 PM
Yep, i have allready a seperate 'water filter'. If there is water in the tank, can that be the reason the motor has a throttle lag on a low RPM?When i bought the motor, i tried it behind a other boat.I was a passenger and i didn't notice the throttle lag. Maybe there are more reasons...A service manual is only in english? Allright, it is good for me. Thanks, Mish
  #7
Old April 8th, 2006, 11:54 AM
The F100 had a dip when I the motor runs stationair (1500 tpm) and i gave full throttle. When the motor runs 2000 tpm, the problem solved.But later...The F100 runs stationair a little bit too hard (1500 tpm). I turn the black stak at the end of the trotlle cable a in (it makes the cable a litlle shorter). After this modification, the dip disapeared! Is it possible when the throttle cable is too long, the valve in the carburator (when i give full throttle) does't stand right? Maybe the valve go too far...? I dont know.Ɓnyway, the problem is solved!Thanks, Mish
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 Yamaha F100 Start/Acceleration problem. diveextreme Yamaha & Suzuki Outboards 4 July 27th, 2004 01:08 PM
Yamaha F90 vs F100 Slowtoplane Yamaha & Suzuki Outboards 3 July 2nd, 2004 12:36 PM
Yamaha F100 Acceleration Sputter billcallahan3089 Yamaha & Suzuki Outboards 2 June 16th, 2004 03:54 AM
YAMAHA F100 Nuriyamasan Yamaha & Suzuki Outboards 3 August 28th, 2003 10:48 PM
Yamaha F100 stauter99 Yamaha & Suzuki Outboards 2 March 5th, 2003 07:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
