  #1
Old March 25th, 2006, 08:52 AM
oceancpt oceancpt is offline
Default Yamaha F25ELHZ 25 HP four stroke timing belt
Hello all,What is the reccomended time/hours interval for timing belt change on these motors? Thanks.
  #2
Old March 25th, 2006, 09:24 AM
rodbolt rodbolt is offline
Default Re: Yamaha F25ELHZ 25 HP four stroke timing belt
its inspection evey 200 hours or 1 year and replacement at 1000 hours or 5 years. you really really need a service manual. skip an oil change and buy the manual. the inspection procedure is in the manual as is the valve lash checking procedure. that motor is refered to as a non interference motor so if the belt does break no engine damage should occur due to valve to piston interference. the service intravels are in both the service manual and the marine tech guide but the service procedures are only in the service manual.
  #3
Old March 25th, 2006, 11:25 AM
Thank you again rodbolt! After spending sometime on the site I see that you are a legend here. I will ask that the belt gets a detailed inspection during its 200 hour service, as the engine will be 5 years old in June. I will leave it to the professionals to change it. I only do my best to keep the motor well oiled, cooled, and clean to prevent corosion. The rest is best left to the people who work on engines all the time. Thanks again
  #4
Old March 25th, 2006, 12:41 PM
no worries, the 5 year intraval is a guidline. if your belt slack is in acceptable limits and not fraying nor craking odds are it will live. and as that motor is a non interference motor if it breaks it will stop running but wont wipe the engine. but do ask for the pages I posted. makes both feel better about the work performed. I am NOT a legend, I apperantly have no life
  #5
Old March 25th, 2006, 05:43 PM
If you enjoy what you do with your time then you do have a life. It's a BAD! feeling when your engine quits on you. No matter what boat you are on. In 03 I crossed san pablo bay in not so good set of conditions. Then onto the petaluma river WOT, she quit.Gas coming out of the carb. I was thankfull she did not quit in the bay. after draining the curb she started right up. But ever since then the fuel tank gets cleaned right before she goes on the dry. Usually around Thanksgiving. She sometimes ventures passed the Golden Gate bridge. I do all that is required and hope I never loose power again. I am not worried about the T/B breaking though if it looks good and it's tight enough. Thanks again.
  #6
Old March 25th, 2006, 05:48 PM
if you took away the customer/lack of maint fuel problems and the customer/lack of cooling system maint problems I would be on welfare. the amount of actual problems with the gear is very minimal, however if the CDI on your 25 says motoraloa its a mercury with a silver/blue paint job and the electronics typically are not as bullet proof as hitachi stuff. however so far I have only seen two motorola CDI units fail and one does not count cause the engine had gone swimming at the inlet.
  #7
Old March 26th, 2006, 12:40 AM
Aah, good point. I will check into that tomorrow. The CDI I mean.I do know that either the cylinder head or the block is made by Mercury, hence the above than average noise for a 4 stroke. By the way, I 've been using yamaha ring free in the fuel ever since the engine passed it's break in period. Do I need to perform decarbonization once in a while? Also the gear case always gets mercury high performance gear oil, I like the staff. I am not sure about the yamalube 10/30 I use though, that's why the longest I went without an oil change is 50 hours. There is always something better i quess the key is care and maintenance.The other thing is: Is it better to drain the curb or let stabilized fuel in it? When I do drain the carb, I turn the engine over with the drain screw removed in hopes that any residual fuel gets pushed out of the curb. I do that after I spray fogging oil into the cylinders. Ah, all these questions, no wonder you feel like you have no life.
  #8
Old March 26th, 2006, 02:12 AM
the oil change cycle may be excessive but at less than 2qts its dirt cheap. tipping the engine may be a bit overboard as it will drain anyway. the HP gear lube is a tad pricy for the application but is a superior oil. in anycase seems what your doing is working so keep it up. the reason for the noise is that motor has 2 firing pistons and 1 balance piston and adjustable overhead valve rocker arms. all in all a decent engine though. 90% of the problems trace back to contaminated/old fuel.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
aq125a timing belt/timing marks RandyJ Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 May 8th, 2007 11:24 PM
Yamaha F150 2006 Timing Belt Bluefish Yamaha & Suzuki Outboards 9 March 20th, 2007 06:25 PM
Tensioning timing belt 50hp 4 stroke Zerex Mercury & Mariner Outboards 7 October 30th, 2005 06:38 PM
Yamaha 225 Timing Belt PeteSmyth Yamaha & Suzuki Outboards 4 April 4th, 2005 08:29 AM
Yamaha F40 timing belt and mystery sound question Tod Osier Yamaha & Suzuki Outboards 10 February 24th, 2005 04:44 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
