  #1
Old March 22nd, 2006, 07:03 PM
mike steuermann mike steuermann is offline
Default 1990 yamaha 50 hp jet drive outboard
My son recently purchased a boat with the 50 hp yamaha jet drive outboard. How do you test run the engine? There doesn't appear to be any way of hooking up a hose.
  #2
Old March 23rd, 2006, 03:39 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: 1990 yamaha 50 hp jet drive outboard
Welcome to iboats. You can run it for up to a minute or so without water. There is no water pump impeller to burn out as with a conventional gearcase. Water from the propulsion impeller slings some of it's output up to the powerhead. Just don't let it get hot.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old March 24th, 2006, 05:53 PM
rodbolt rodbolt is offline
SDO NOT repeat DO NOT run that motor without the flush attachement. it DOES have an impeller ,just like an outboards, for engine cooling. 1 min and the pump assy is toatetoed and the kit is about 80 bucks. on the port side just above the "bubble" you will see a small plug, almost like an outboard drain plug, may say wash on it. the flush adapter is about 13 dollars and screws in place of that plug. outboard jet, for some reason , liked to use a seperate seawater pump on all I ever saw, berckly,hamilton sportjet and a few others did not.
  #4
Old March 25th, 2006, 05:07 AM
summers1996 summers1996 is offline
I built my own flush attachment with a stainless allen head bolt 2 hose clamps, 1 nut, 1 washer, a section of garden hose and a garden hose male connector. The plug is not metric. Bought everything at ACE hardware. Drill a hole thru the bolt as large as possible. Run the nut up about 1/2 an inch and slide a rubber washer up to the nut. Attach about a foot of garden hose with a hose clamp to the head of the allen bolt. Connect a male harden hose connector to the other end. If you post your email, I'll send a picture of it. Works fine but u have to hand tighten it to the jet pump, it's hard to get a wrench down to it. Or buy one. I don't think it would ever be wise to run any water cooled motor without water.
  #5
Old March 25th, 2006, 08:20 AM
Thanks for the replys. I would like a picture of the flush attachment that Summers1996 made.E-mail, steuermannm@yahoo.com
  #6
Old March 25th, 2006, 08:41 AM
be careful with the threads as most the outboard jets, in fact all the outboard jets I work on that were built for yamaha had metric threads and in fact use the same plug and gasket as the gearcase vent plug. its the same flush attachment made for the smaller yamaha outboards.
  #7
Old April 20th, 2006, 06:25 PM
Larry McDavid Larry McDavid is offline
rodbolt, Do you happen to know where I could find one of these attachments online? I have a 99 C40TLRX with an Outboard Jet kit. My local dealer doesn't stock them. Can the attachment be used to run the motor faster than idle? Thanks,Larry
  #8
Old April 21st, 2006, 03:59 AM
beats me, its in the yamaha accesories manual. its just a short piece of hose with female garden hose on one end and the correct male thread on the other. do NOT run above an idle on the flusher. bad things can and sometimes do happen. I think some of the jet skis run the same flusher.
  #9
Old April 21st, 2006, 07:24 AM
I found it on the Yamaha outboard page. http://www.yamaha-motor.com/outboard...46/detail.aspx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Force 120 HP L-Drive 4 Cyl. Swap? Bullwrinkle Force & Chrysler Outboards 2 August 28th, 2006 11:34 AM
yamaha 200 1990 outboard shift rod broken artis Yamaha & Suzuki Outboards 2 October 19th, 2004 05:58 PM
1990 Bayliner L-Drive rebuild Kingsman Force & Chrysler Outboards 0 July 25th, 2003 01:51 PM
1990 Bayliner w/ Force L Drive to OMC 5.0? _ JT _ Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 7th, 2003 10:23 AM
1990 Yamaha 115 hp outboard gslay Yamaha & Suzuki Outboards 2 July 8th, 2001 05:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
