  #1
Old March 17th, 2006, 06:09 PM
w2much w2much is offline
Default Adjusting oil pump at WOT Yamaha 50 HP
50 ETLK 6H5 L 412845 - Yamaha OEM manual states to adjust the oil pump to the carb at WOT. My question is regarding the oil pump lever postion. Forward towards the carbs is max oil pump at Wot? Picture is unclear and description is dark and inconclusive. Oil pump lever swings forward(towards the carbs) and back (towards the head). Is forward max oil pump at WOT? Need to know before next outing. Have been using premix 50 : 1 in the meantime. Nylon connector was broken so I do not know original adjustment. Thank You for your replies they are greatly appreciated.
  #2
Old March 17th, 2006, 07:11 PM
rodbolt rodbolt is offline
Default Re: Adjusting oil pump at WOT Yamaha 50 HP
beats me, I cant remember. open the throttles to the WOT position, thread the connector on the oil control rod so that the arm is the correct distance from the stopper.mark the oil tank and go play using premix until proper operation is verified. I cant remember if the 50 used index marks or arm to stopper clearence, thats why I use the manuals.
  #3
Old March 18th, 2006, 05:25 AM
Rodbolt Thank You, I appreciate your imput. I will continue to use a premix. I would like to figure this out though so that I am not loading up the engine with too much oil. At some point I imagine this will become an issue. (Too much carbon buildup ,fouling plugs ect.).The lever stops all the way forward and of course all the way back. There is also a straight up position which has a mark on it. The Yamaha OEM manual is really vague and only states to adjust the pump at WOT.Duuuhhhhh. Thanks Yamaha!
  #4
Old March 18th, 2006, 05:42 AM
Ray Neudecker Ray Neudecker is offline
On most Yamahas, the oil pump wide open is the direction it will go when the pump arm is disconnected. This is a safety measure in case the arm is disconnected.
  #5
Old March 18th, 2006, 06:22 AM
Which is what occurred with this engine as the nylon connector broke.What a smart feature. I love it.When released from the pump arm the lever seems to sit in a straight up position rather than forward or back. There is some spring action which seems to make this position default so to say. At a fast idle using premix fuel with the oil line disconnected from the top carb will I be able to notice significant difference in oil output by working the oil pump lever forward and back?
  #6
Old March 19th, 2006, 04:04 AM
Doubtful. At best it is more like a drible than a spray.
  #7
Old March 19th, 2006, 06:09 AM
Thats what I witnessed, which is good.It had me concerned that the pump was not delivering enough oil.The manual depicts a spray but I have found the manual to be quite vague.So really my question has been answered.Just for curiousity sake then, does the pump just deliver to the carb and vacuum takes over from there?<P>Ray and Rodbolt Thanks you again for your time and answers.<P>
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water Pump for Yamaha l4 3.0L I/O JeffM1000 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 August 14th, 2008 06:12 PM
Yamaha 9.9 water pump johndoe Yamaha & Suzuki Outboards 2 July 6th, 2008 11:46 AM
90 hp Yamaha Fuel Pump foxden Yamaha & Suzuki Outboards 2 June 28th, 2004 01:17 PM
200 HP Yamaha oil pump problem! Need HELP!!! captrich Yamaha & Suzuki Outboards 5 July 5th, 2002 03:42 PM
Yamaha 40 hp water pump Lazlo Yamaha & Suzuki Outboards 1 March 1st, 2001 12:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
