I just purchased a 2004 Yamaha 25hp 2 stroke. I'm trying to do everything right. This motor has two carbs one for each cylinder. The mechanic at the dealer I bought the motor from said to run the gas out of the carbs. I only run the motor on weekends so I dont want the carbs to gum up from lack of use. However my question is, Will I be running one cylinder lean and damage my motor since both carbs are unlikely to run out of fuel at the same time?
