  #1
Old March 10th, 2006, 05:14 PM
ST ST is offline
Default 1987 Yamaha 9.9: Where is the Idle Fuel Mixture screw? (pic)
I read sometimes ago at this forum that if your engine seems to wanna quit if you increase the RPM, but picks up the RPM when you partially closed the air inlet opening with your tumb, this indicates that the engine is lacking fuel. When the engine gets hot however, this problem seems to go away.That's is what's happening to mine, so I intend to make the fuel mix richer, but can't find where the screw is in the carb. Would someone(s) help point me in the right direction please, here's the carb's diagram; thanks![img] ]http://www.boats.net/yamaha/partsystem/browse-model-parts.pl?type=component&*******=cef029d16ac7cd1961 1648c07985e645&catalog=Outboard&year=1987&model=FT 9.9ELH&component=376100[/img ]031006 19:19 PST url edited...st.
  #2
Old March 11th, 2006, 05:01 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: 1987 Yamaha 9.9: Where is the Idle Fuel Mixture screw? (pic)
#13. Turn it clockwise for less fuel, ccw for more fuel. I'd try 1/8 turn ccw. More if necessary 1/8 at a time. It should chug slightly. Don't adjust for the smoothest or the fastest idle running characteristics. It needs more fuel than that for acceleration. Roughly 1/4 ccw from smooth and fast.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old March 11th, 2006, 06:27 AM
ST ST is offline
Hi Willy,Thanks for taking the time to respond and gave valueble pointers. I've just tried and played with it per your directions, but before I am done, the wife showed up and warned me it's "too early"-neighbors (08:00AM in Calif.)- oh well; I'll continue a little later...But thanks again!
  #4
Old March 11th, 2006, 01:01 PM
ST ST is offline
I continued tuning up the carb today, tweeking with screw no. 13 as indicated by the drawing above, and seems to be able to rev up the engine to a higher RPM without much hesitation, even though I feel it's not perfectly smooth. Perhaps, cleaning the carb (again) is next...thanks Willy!
  #5
Old March 12th, 2006, 04:36 PM
Silvertip Silvertip is offline
If you are making this adjustment in your driveway using muffs, you will likely have to readjust it when the boat is launched. There is no back pressure on muffs so when the motor is dunked the increased back pressure changes the engines idle mixture requirements. If you can run it in a barrel that would be better.
  #6
Old April 16th, 2006, 03:02 PM
ST ST is offline
Upinsmoke,Thanks for your input! Ok, I'll play again with the adjustment as soon as I get a change to launch this; hopefully soon....!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Idle mixture screw out 7 turns not 1 1/2 tfbrown1270 Johnson & Evinrude Outboards 20 October 22nd, 2006 11:32 PM
What's correct idle mixture screw setting. milkyway Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 June 19th, 2006 10:19 AM
Idle mixture screw on a 91 50HP force shindig888 Force & Chrysler Outboards 5 June 5th, 2005 03:06 PM
location of the idle mixture screw... sqb Mercury & Mariner Outboards 1 June 9th, 2004 06:28 AM
92 130 idle mixture call for pilot screw 7/8 ths bonitoman Yamaha & Suzuki Outboards 1 February 21st, 2004 12:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
