I bought a used Aluminum lifetimer boat recently and it came with both the Yamaha multi function gauges, Speedo/fuel/time and Tach/trim. Unfortunately someone opted to put in aftermarket gauges. The Tach is working minus the trim and there is power to the speedo but that's about it. Unfortunately it appears as though the original plugs have long been severed. I would like to get these gauges up and running. I sucked some water out of the speedo and it may be working now. At least when I blow in it there is and indication its working. Haven't tried it in the water yet. I believe both gauges are the same age as the boat and engine, 1991. The most important issue is the fuel gauge. It shows empty and the warning light is flashing. The white with blue wire is connected to the sender wire but there is a second solid white wire which goes no where? When I apply power to the solid white wire the fuel gauge doesn't work but the digital display goes to 16?<br />I believe the sender has been replaced. Does the sender have to match the gauge? The sender wire has a voltage reading of around 5 volts. The sender wire is also connected to the after market gauge. Would this make a difference? Thanks. PS the aftermaket fuel guage isn't accurate either. A full tank indicates about 3/4?
