clanton
- Jul 9, 2001
- 4,876
Johnson 140 4 stroke
This engine over 700 hours<br /> No trouble codes, no overheat<br /> Valves OK, never adjusted<br /> Orignal waterpump, still pumping, replaced<br /> Orignal spark plugs, still sparking, replaced<br /> Using no oil<br /> dripping some oil, under throttle body, where<br /> the crankcase is vented, needs inprovment here<br /> Shifting OK<br /> All engine Zinks, replaced<br /> Some corrosion on block and bolts<br /> 200 more hours, and gearcase bolts would not have come out without heat.
