  #1
Old February 15th, 2006, 05:29 PM
hitch hitch is offline
Default 1999 Yamaha 90 water pump impeller change
Bought this motor last year without a manual. It's running great, but I would like to change the impeller. Loosened all bolts for lower unit but couldn't separate even using a mallet. Does anyone know if there is something else connecting the lower unit or shaft to the motor? The motor has been used in salt water so I'm hoping that I don't have a corrosion problem.
  #2
Old February 15th, 2006, 07:08 PM
ob ob is offline
Default Re: 1999 Yamaha 90 water pump impeller change
That's why it's best to get a manual first.There is shift rod linkage that needs to be disconnected first.Best to make up a couple of the bolts you removed first to release the strain on the shift linkage.Also make sure you know the location of "all" of the bolts to be removed.
  #3
Old February 16th, 2006, 09:11 AM
Thanks for your comments. I was holding off ordering the manual until I received confirmation that there is something else to disconnect (rather than corrosion which would cause me to take it in for service). Just ordered the manual today. Do you happen to know if special tools required to disconnect the shift linkage? The motor is in Florida; I am in Wisconsin. Want to make sure that I bring down everything I need to get the job done correctly when I return to Florida next month.
  #4
Old February 16th, 2006, 06:40 PM
ob ob is offline
No special tools required other than common wrenches and socket set etc...Let us know how it goes once you get to the motor.
  #5
Old February 17th, 2006, 11:58 AM
I will. I guess the half-key can be a problem. See this website: http://www.thehulltruth.com/forums/t...=12&mid=885897
  #6
Old February 19th, 2006, 08:01 AM
bigbrownbuku bigbrownbuku is offline
Master Chief Petty Officer
how many bolts exactly did you remove? unless your shafts are corroded in there is no disconnecting the shift shaft its simply a male and female spline.
  #7
Old February 21st, 2006, 08:34 AM
I only removed the exposed ones; didn't know about the two unexposed, so I do not expect any problems. Thanks for your comments.
  #8
Old July 28th, 2008, 08:59 PM
jjgibson18 jjgibson18 is offline
I just replaced my water pump impeller/gaskets on a c90 1999 Outboard
There is a black plastic cap that houses a bolt to remove the zinc anode
Once removed, the zinc anode can come off easily, furthermore, there is another bolt underneath the zinc anode housing that has to come off, then the lower unit will drop - make sure to disconnect the speedometer cable
Altogether there should be 6 bolts holding the lower unit on
Hope this helps,
Jonathan Gibson
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 Evinrude 9.9 4-stroke water pump change hunterbob Johnson & Evinrude Outboards 1 March 17th, 2005 06:47 PM
Johnson 70 water pump change. Can't remove impeller salmonchaser20 Johnson & Evinrude Outboards 4 September 28th, 2003 08:45 PM
How do I change the water pump impeller OhNoMrBill1960 Mercury & Mariner Outboards 4 July 11th, 2003 11:34 PM
How do I change the water pump impeller OhNoMrBill1960 Mercury & Mariner Outboards 3 July 11th, 2003 11:20 PM
How do I change the water pump impeller OhNoMrBill1960 Mercury & Mariner Outboards 2 July 11th, 2003 08:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
