Skeeter#2
- May 10, 2004
- 26
Signals at high speed 3000 rpm and up, will turn off as soon as rpm is reduced even a little only to come on again after a short while.Does not seem to run hot to the touch. can the thermostat open too late, (at boiling point opens wide when tested on the stove in water) and cause the pressure relief to open and drop the waterflow indicator? have done plenty, new gaskets,pump kit,flow indicator sep03 worked perfect after that, now starting again.Question the old relief spring is not up to its job...or is something else?
