  #1
Old January 31st, 2006, 05:19 AM
Bandaid Bandaid is offline
Default Yamaha 225 Excel fuel Flow ( Help needed!)
Friends, I own a 1987 225 Excel that has been having I think fuel flow problems at 3/4 to full throttle. It sounds like the motor is not getting enough gas and the bulb is more easily collapsable than usual though it does not completely collapse. It seems like if I pump the bulb while underway this improves the problem. On the Excel I am having a hadr time locating the fuel filter or pump. I would appreciate any assistance with diagnosing this problem. Thanks.Charlie
  #2
Old February 1st, 2006, 04:10 AM
Ray Neudecker Ray Neudecker is offline
Default Re: Yamaha 225 Excel fuel Flow ( Help needed!)
There are two fuel pumps mounted on the port side of the intake. The filter is also mounted there. On those models I highly reccomend bypassing the quick disconnect fuel connecter with a straight line and also the filter itself. Installation of a fuel water seperator in the line will take the place of the engine mounted filter. There is no real doubt the problem is caused by a fuel restriction. It could also be the time to replace those fuel pumps and have the carbs gone through. A fuel restriction will quickly kill that powerhead.Much cheaper to be sure the problem is cured.
  #3
Old February 1st, 2006, 02:50 PM
Ray thanks for the good advice. I know the fuel pumps have not been replaced in 10 years so it is probably well worth the investment. Are you suggesting just removing the inline filter? The water seperator on my Grady (24' Offshore '85) is under the floor near the transom. Thanks again for the advice. Keep the suggestions coming. Regards,Charlie
  #4
Old February 1st, 2006, 03:16 PM
rodbolt rodbolt is offline
and when you remove the filter element from the powerhead please install the 10 micron water seperator avalible from your yammy dealer.
  #5
Old February 2nd, 2006, 04:36 AM
I am suggesting you eliminate the complete filter assembly and make sure the present water seperator filter is fresh or use the one reccommended by Rodbolt, The restriction caused by the engine mounted filter is in the assembly itself and not the small filter enclosed in it.
  #6
Old February 4th, 2006, 06:56 PM
Canuck 16 Canuck 16 is offline
Ray, is this suggestion only for the excel model or should I think about eliminating the under cowl filter assembly on my 89' 200?Cheers... Canuck 16.
  #7
Old February 5th, 2006, 02:41 PM
Really true for all V-6's that used the small bowl fiter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 Excel Question Trickworm Yamaha & Suzuki Outboards 1 July 10th, 2006 10:03 AM
What's a Yamaha Excel? crbenny Yamaha & Suzuki Outboards 11 July 24th, 2005 03:23 AM
Yamaha 55 fuel flow problem goof01698 Yamaha & Suzuki Outboards 2 July 22nd, 2005 01:26 PM
89 225 Yamaha V6 Excel Overheating Key Largo Yamaha & Suzuki Outboards 14 March 24th, 2005 07:01 PM
Yamaha 1997 200 SWS Fuel Flow NavMan 4380 kavika Yamaha & Suzuki Outboards 4 November 30th, 2004 07:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
