Hi all now i have finally sorted out the pree mix at 50/1 on my 8 hp yamaha it is an old thing in late 80.s i can get the number if need be but it is old <br />ok now the good bit i fired it up after fitting new coils as i bought it needing them it had bn laid up for about a year so was told to make sure that it is pumping water ect <br />it started no problem and the pee hole is pumping water no problem i started it in a big bin with plenty of water in and it ran great for sometime then i went out and put it on my boat it ran great for about 30 or 40 mins no problem then the problem started it would cut out and be hard to start but would start and go for maybe a minute or so then the same again it was still pumping water ect and reving ok just hard to start and would cut out.<br />i had to use elastick bands to get a good seal on the fuel pipe as the round washer typ seal was leaking but it seamd to hold fine <br />it felt to me as tho it was flooding and cutting out i may be wrong can anyone else advise any other thing that would cause it to cut out like that there was no fuel leaks ect even with the elastic band wound around the conection to make a seal and no air was leaking ect from the fuel pipe also just rememberd the vent on the tank was open as i had checked that incase it was under presure <br />thanks all sorry about the long story
