  #1
Old December 1st, 2005, 07:40 AM
dancamp007 dancamp007 is offline
Default more drain holes to prevent salt damage Yamaha
I've taken my 1993 Yamaha 9.9 outboard completely apart (except the block) to clean out the salt deposits. I found a lot of salt accumulations in the head which I've cleaned out. Then I opened up the upper drive shaft housing and found a whole bunch more salt accumulations that I meticulously sanded away. In all honesty, I can't understand why Yamaha would create so many places for salt to accumulate with no way to get out. On the very back of the upper housing there is a pocket where the water does not drain out and I was wondering if I could put a drain plug in there or at least some sort of valve that I could squirt water into right where the salt accumulated in these pockets. I could fill them with JB Weld until it's thick enough to thread a water hose **** of some sort. It doesn't seem like there would be any pressure there that would need to be maintained. Any comments on this from anybody? I am following another guys suggestion (http://www.intergate.com/~arenius/Ya...yamaha9_9.html -- no longer available in web)about adding some flush valves on both sides at the top, but why not right where the salt really holds up too.
  #2
Old December 1st, 2005, 01:07 PM
Default Re: more drain holes to prevent salt damage Yamaha
To be a little more precise, this is a 1993 Yamaha T9.9MXHR. The exact location that has no way of draining is on the rear of the upper casing behind the pee hole. It has a rubber gasket surrounding the top called the "cover, upper casing" (#15, 6G8-45151-00-00) gasket shown in the upper casing view on (http://www.yamaha-motor.com/outboard/parts/home.aspx). I don't really understand why this little enclosed area even exists. Why couldn't it have two little holes in the bottom of each side where the salt holds up so the water could drain out either into the upper casing or outside (it already sits next to the pee hole). Does anybody know why this little compartment even exists besides to create salt decay?
  #3
Old December 3rd, 2005, 10:11 AM
Found answer at http://www.yamahaoutboardparts.com/c...=001561#000002 thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Drain Holes bvwebb Rinker Boats 1 July 10th, 2006 05:13 PM
How to define salt damage to boat I am considering buying sail&power Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 11 February 19th, 2006 03:33 PM
Salt water damage/corrosion andeline1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 October 26th, 2004 07:03 AM
How to prevent exterior damage?? Seagull6 Boat Topics and Questions (not engine topics) 5 December 1st, 2002 06:19 PM
Salt water in engine....damage??? jcgodwin Non-Repair Outboard Discussions 0 June 14th, 2001 06:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
